stancanyon
May 08, 2022Follower
rbr 50 + 2 sats: can't sync all of a sudden....it did, got all green, then sats went magenta again
worked fine for several years, then sat dots went magenta in the app, re synced, ok for ten minutes, then the red eye of death (so dramatic).... resync did not work at all.....please point to reset ...
KevinLiT
May 09, 2022NETGEAR Moderator
Hi stancanyon,
I understand that you are having issues syncing your RBR50 router to the RBS50. Since the RBR50 was able to sync for a couple of minutes before it disconnected can mean that it is time for a firmware update. Below I have embedded links to reset your RBK50 system as well as the most recent firmware update.
Please navigate to the link below for reset instructions for your RBK50 system:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Please navigate to the link below for the firmware download file for your RBR50:
https://www.netgear.com/support/product/RBK50#RBR50%20(Orbi%20Router)%20Firmware%20Version%202.7.4.24
For more information on manually updating your RBK50 please navigate to the link below:
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
Let me know if you have any additional questions!!
Best,
Kevin
Community Team
