Ian_Dickson
Jan 03, 2020Aspirant
RBR 50 and Arlo Ultra Cameras
I recently bought an Arlo Ultra wireless security system to work with my Orbi System (RBR50 and X4 RBS50). My broadband download speeds within my house are over 200mB/s. I'm finding that the wifi signal strength just outside the house is dropping a lot and the Arlo cameras are struggling to pick it up. Using a broadband speed app the download speeds at the cameras are only around 10mB/s and sometimes they don't even recognise the wifi leading to them being unable to send back pictures etc. My RBS50's are on 5GHz and I wondered if there is a way to get the signal any stronger to the cameras. I have the RBS50's as close to the cameras as I can. Would the 2.4GHz work better at all? Does anyone else use a wifi camera system with their Orbi network? Thanks
What is the exterior walls of your home?
Foil lined insulation, steel side, plaster, adobe, metal lathe, etc. This is kind of important as certain materials are great at blocking wifi signals.
How big is your home?
Have you tested the speed at the satellite to ensure its not the backhaul thats got issues?
- Ian_DicksonAspirant
Hi, I'm UK based. The walls are brick built and windows all double glazed which I appreciate will be a factor. The home will be approx 3000sqft in area. How do I test the speed at the satellite? Thanks Ian
You can test the speed at the satellite by hardwiring into it. You can also test wirelessly at the satellite to have a comparison for wireless speeds. If its slow even by the satellite, then the brick isn't the issue. If speed/reception are fine in that spot, the brick is causing your issues.
Brick is great at blocking wifi sadly. You might have great reception on one side of the brick and horrible on the other. The only way to know is to test it. https://eyesaas.com/wifi-signal-loss/
Arlo ultra might not be your best best with brick exterior walls. if its possible to hardwire in the camera's, that might be better in your circumstance.
