faizankhan85
Mar 18, 2022Aspirant
RBR 50 compatible with Virgin 1gbp connection / Superhub 4 or 5?
Hello All Currently I use by Orbi RBR50 with the Virgin Superhub 3. However, I am looking to upgrade to the 1gbps package, which I believe comes with their Superhub 4 and/or 5. Are there a...
Mar 18, 2022Guru - Experienced User
Wireless AC isn't going to hit gigabit speeds over wireless. You should still be able to hit gigabit speeds over the wired connection though.
faizankhan85
Thanks - but i would assume at least 5-600mbps right?
have you tried it with the superhub 4 or 5?
