enewbauer
Mar 16, 2020Guide
RBR 50 Continuously Losing Connectivity
TL;DR: My RBR50 will not maintain a connection to the Internet, even though the wifi stays active. Problems just started a few days ago after over a year with no issues. The problem is the same when ...
enewbauer
Mar 20, 2020Guide
Sorry for the delayed response and thank you for these ideas. I implemented the changes you recommended and will see how it goes for a few days.
I'm also going to try swapping out the modem, again, to see if that is part of the problem. While this would be the second modem swap in a week, as I initially thought that was part of the problem, perhaps it wasn't and maybe the new modem is introducing a shakiness that the Orbi does not react to well.
Mar 20, 2020Guru - Experienced User
Sounds good. Please leave feed back to the questions presented as well. Gives us some idea of your configuration.
enewbauer wrote:Sorry for the delayed response and thank you for these ideas. I implemented the changes you recommended and will see how it goes for a few days.
