enewbauer
Mar 16, 2020Guide
RBR 50 Continuously Losing Connectivity
TL;DR: My RBR50 will not maintain a connection to the Internet, even though the wifi stays active. Problems just started a few days ago after over a year with no issues. The problem is the same when ...
larrymcgovern
Nov 11, 2020Aspirant
My router loses connectivity every night. I have to reboot the modem to reconnect. This just started happening after having the router since Sept 24, 2020.
Nov 11, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
larrymcgovern wrote:My router loses connectivity every night. I have to reboot the modem to reconnect. This just started happening after having the router since Sept 24, 2020.
