Kirika
Aug 03, 2021Aspirant
RBR 50 Corrupted - Will Not Allow Firmware Update - Possible eMMC Corruption?
Router began acting weird and having network access errors. Attempted to perform multiple factory resets 30-30-30, etc. etc. Router will not return to its original state (retains my SSID instead of r...
Aug 03, 2021Guru - Experienced User
Does re-loading v104 on top exhibit the same problem?
You only need to press the reset button for 15 seconds and release should do a full factory reset.
Where are you seeing these error entries?
What browser are you using? Try FireFox or MS Edge.
- KirikaAug 04, 2021Aspirant
Loading v104 has the same problem.
I'm seeing the messages in a PowerShell (PUTTY output from serial port). I see it when it's trying to initialize firmware that I upload to the unit using tftpd64.Refer to the images posted.
