Kirika
Aug 03, 2021Aspirant
RBR 50 Corrupted - Will Not Allow Firmware Update - Possible eMMC Corruption?
Router began acting weird and having network access errors. Attempted to perform multiple factory resets 30-30-30, etc. etc. Router will not return to its original state (retains my SSID instead of r...
Kirika
Aug 04, 2021Aspirant
Loading v104 has the same problem.
I'm seeing the messages in a PowerShell (PUTTY output from serial port). I see it when it's trying to initialize firmware that I upload to the unit using tftpd64.
Refer to the images posted.
Aug 04, 2021Guru - Experienced User
Probably something corrupt and needs to be look at by NG.
- KirikaAug 04, 2021Aspirant
Yeah, sadly my router is out of warranty *sigh*.
I already replaced my system with the SXK80. Now to figure out what to do about my RBS50 satelites :-/.- FURRYe38Aug 04, 2021Guru - Experienced User
Might see if the RBS50 will ethernet connect to the 80 series. They do for the Orbi 8 AX series. They might for the pro.
