bhanna69
Jun 19, 2021Aspirant
RBR 50 crashed
My RBR50 crashed last night but the satellite still works. I hate to waste the satellite. I went ahead and replaced the system with an RBK752, but it would be nice if I could get a reasonable price o...
bhanna69
By crashed I mean that when I got up this morning I couldn't connect to the internet. The light on my cable modem that shows the connection to the router was not lit. When I connected a computer to the modem, the light came on and it connected to the internet. I tried several things with the router to reset it, power cycle, etc. and it would never connect to the modem.
As far was as issues with refurbished RBR50s, I read them on this board and they were verified by board administrators.
michaelkenward
Jun 20, 2021Guru - Experienced User
Remember to do things in exactly the right order when recovering from that sort of crash.
It may help to reboot the whole network in the right order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
You have reset the RBR50, so you'll have to set it up again from scratch. Unless you have a copy of the saved configuration file.
Questions about the RBR50 are really best thrown at the appropriate section, where Orbi users hang out.
That's probably here:
Orbi - NETGEAR Communities
Orbi technology is kind of different from the bog standard routers covered here.
