linwa
Nov 24, 2018Tutor
RBR 50 firmware 2.2.1.210 dropping signals every couple minutes
Orbi RBR50 with 1 satilite. firmware 2.2.1.210 dropping signal every minute or so. My cable company replaced modem after modem stopped working but the "Link" light on modem is blinking amber and my s...
Nov 24, 2018Guru - Experienced User
What FW is currently loaded?
linwa
Nov 26, 2018Tutor
The RBR50 router is connected to Arris TM822 cable modem. Firmware showing is 2.2.1.210. Also have phone connected to the Arris.
I also have have a brother printer/fax/scanner connected to the ethernet port on the RBR50 router.
- minivagNov 26, 2018Aspirant
I belive there is a problem with the sw. But we can work with it and i belive time is your friend here.
Here is what i do.
1. Turn off both Orbi router and satelite and pull all ethernet cables out off them both. except the one to the modem.
2. Turn on the Orbi router. Wait 5 min. check that the system is working.
3. Turn on the Orbi satelite. (still no cable). Wait 5 min. Check if the satelite shows up in the orbi app.
3a. If not. The press the sync button on router and the sync button on the satelite. again wait 5 min.
4. If you have any ethernet connected devices. The put them in one at a time starting with them in the router. give every one time. then put the ethernet cable in the satelite (again time)
5. Now cross your fingers that you dont have any power failure. Because then you have to do it all over again.
- BuckFossNov 26, 2018Aspirant
Did this actually work? I'm having the same problem.
- FURRYe38Nov 26, 2018Guru - Experienced User
Please try any of the suggestions. Please also give answers to some of the question presented so we have a better idea of your configuration being used.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
