chetm
Aug 10, 2019Tutor
RBR 50 firmware wont update automatically or manually
According to my Orbi IOS app my Firmware version for my RBR 50 is 2.3.1.60. When I check for updates I either get a message that an update is available or there was a checking error. When I do get ...
- Aug 12, 2019
Thanks. I will try Firefox next. I may reset and try from scratch as suggested.
Chetm
CrimpOn
Aug 10, 2019Guru - Experienced User
The current firmware for RBR50 is 2.3.5.30. Connect a web browser (Safari, Chrome, etc.) to the Orbi, which may be "orbilogin.com". (I prefer to use the actual IP address which in my case is 192.168.1.1), enter "admin" for the user ID and the admin password for the Orbi (which is, of course, different from the WiFi passwordl) The web Home Page will display the router version in the upper right. If it is 2.3.5.30, then the RBR50 firmware is current. If it is not, then navigate to the Advanced Tab->Administration->Firmware Update.
Questions about the Orbi IOS app are probably better addressed to the actual "Orbi App" user forum. My experience is that most of us on this forum use the web interface most of the time.
Good Luck
chetm
Aug 10, 2019Tutor
Forgot to mention that I will check the firmware version on the web again.
thanks
Chetm
