lfd346
Dec 21, 2019Aspirant
RBR 50 Firmware
Can someone tell me the correct firmware for the RBR50 I have v2.5.0.38 it appears to me there is a newer version but mine says no? Of course my support expired and have had problems ever since! Tha...
CrimpOn
Dec 21, 2019Guru - Experienced User
Yes, there is a newer version for the RBR50/RBS50: https://kb.netgear.com/000061530/RBR50-RBS50-Firmware-Version-2-5-1-8
You are probably aware that there is risk associated with manually updating to firmware that Netgear is not ready to "announce" on the app and web interfaces. People report that this firmware has fixed several issues that appeared when 2.5.0.38 was released.
- lfd346Dec 21, 2019AspirantThanks I tried to manually update it and it told me it was the wrong one! I guess I will wait for it to be forced out! Thanks
- CrimpOnDec 21, 2019Guru - Experienced User
Hmmm. After downloading the two files, you have to "extract" the .img file from each .zip file.
Then, go into the Orbi web interface, Advanced Tab, Administration, Firmware Update, and then select the "Manual Update" tab.
Can you provide the full name of the file that it rejected?
- BobDelpDec 22, 2019Guide
RBS50-V2.5.1.8.img fails for me too.
