brainman33
Apr 05, 2021Guide
RBR 50 Satellite Issues
Hello - After 2 years of great performance, our Satellite is almost unusable. Sometime we can connect to it, but if so, the connection drops shortly afterwards. The Satellite is about 25 feet from t...
Techdude99
Apr 05, 2021Star
Drop back to 2.6.1.40 firmware. It fixed my issues with the buggy 2.7.2.104 firmware. Keep your fingers crossed for the next update.
- brainman33Apr 05, 2021Guide
Trying that now....will update with results.
Thank you for the response.
- brainman33Apr 06, 2021Guide
I was able to update firmware on router, but couldnt update on Satellite. Unfortunately, still running into intermittent drops.
- Techdude99Apr 06, 2021Star
I ran into the same issue with the satellites and had to connect to each on individually (via their IP Address) to update the firmware.
When you're done, that should get you back to where you were before.
Thanks Techdude99 - I feel like that is the solution as well. I do not know how to connect to the satellite via IP. Is it possible to provide instructions?
thanks a lot for the suggestion
Brain
