brainman33
Apr 05, 2021Guide
RBR 50 Satellite Issues
Hello - After 2 years of great performance, our Satellite is almost unusable. Sometime we can connect to it, but if so, the connection drops shortly afterwards. The Satellite is about 25 feet from t...
Apr 06, 2021Guru - Experienced User
25 feet is too close between the RBR and RBS.
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Also try a factory reset after a FW update if you run into problems.
brainman33 wrote:Hello - After 2 years of great performance, our Satellite is almost unusable. Sometime we can connect to it, but if so, the connection drops shortly afterwards. The Satellite is about 25 feet from the base. Both the router and base are on V2.7.2.104. This started for the Satellite on the last firmware version. I recently updated the 2.4 ghz channel, but that didnt help. Any suggestions please?
thank you
Brain
vajim
Apr 06, 2021Master
FURRYe38 wrote:25 feet is too close between the RBR and RBS.
thank you
Brain
25-30 feet
You would most likely put the orbi router in the center of your home then the satellites in the center of the the rest of the area. So really only 25-30 feet between satellites and router.
