brainman33
Apr 05, 2021Guide
RBR 50 Satellite Issues
Hello - After 2 years of great performance, our Satellite is almost unusable. Sometime we can connect to it, but if so, the connection drops shortly afterwards. The Satellite is about 25 feet from t...
brainman33
Apr 06, 2021Guide
I was able to update firmware on router, but couldnt update on Satellite. Unfortunately, still running into intermittent drops.
Techdude99
Apr 06, 2021Star
I ran into the same issue with the satellites and had to connect to each on individually (via their IP Address) to update the firmware.
When you're done, that should get you back to where you were before.
- brainman33Apr 06, 2021Guide
Thanks Techdude99 - I feel like that is the solution as well. I do not know how to connect to the satellite via IP. Is it possible to provide instructions?
thanks a lot for the suggestion
Brain
- FURRYe38Apr 06, 2021Guru - Experienced User
Thanks FURRYe38 . I tried these instructions for Router and Satellite both, but it did not work for the Satellite.
- Techdude99Apr 06, 2021Star
brainman33Hmmm...are you receiving an error? If so, what is it? If not, try a different browser or delete your current browser cache and try again. I can't remember if I had to enable pop-ups for the site but it couldn't hurt to give it a try.
- brainman33Apr 07, 2021Guide
Thanks Techdude99. I thought I could update firmware through the app...didnt realize I had to go to IP of satellite. That worked...now I am hopeful this is solved. Ill update later. Thank you all for th resposes.
Brain
