ikingrma
Aug 22, 2019Aspirant
rbr 50 unable to see the satellite
I have just returned from vacation (up till then all was good). Now my orbi is totally unable to sync withe satellite. I have shut down, restarted and gone through pushng syncing buttons and all ha...
Aug 23, 2019Guru - Experienced User
I would start back from scrach. Reset the route and satellite utilizing the reset botton. Hold for 7-10 seconds and redo the installation manually. Maybe it auto updated improperlywhile you were on vacation.
Another thing to check was do you have your Orbi setup in AP mode? If you're running a combo device (modem with wifi) you'll either need that device setup in modem only mode/passthrough or the Orbi in AP mode.
