MichaelSN
May 23, 2022Aspirant
RBR 50 V2 Satellite Firmware Corrupted
I have an RBR 50 v2 with two satellites. Two years old. One of them woke me up this morning at 4 AM with a blinking white light. The router appeared to be functioning fine, so I tried rebooting an...
May 23, 2022Guru - Experienced User
DO NOT OPEN THE FW File after unpacking it from the .zip file. It doesn't need opening after this. It's not corrupted.
If you have access the the RBS web page at all, you can send the unpacked FW file to the RBS web page using the FW Update section on the RBS web page. https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
MichaelSN
Firmware version is V2.7.4.24.
The modem is from Xfinity and it says it is an ARRIS TG1682G (if that makes any sense).
As for your instructions, I really appreciate your detail and thoroughness, but unfortunately my knowledge is so limited, I'm going to have to pick them apart slowly - very slowly - starting with finding out what a RBS web page is. But thank you again for getting me this far.
- FURRYe38May 23, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-ModeTry option #1 or #2 first...
- MichaelSNMay 23, 2022Aspirant
I did attempt to put my Xfinity modem in bridge mode two years ago when I installed the Orbi, however I failed. And when I contacted Xfinity support for help they failed as well! Anyway, I pushed ahead with the installation and the Orbi system - the router and both satellites - has worked flawlessly ever since with excellent coverage and speed (and that's with the Xfinity network fully functioning). And even now the router continues to work just great but without the satellites. So it makes me suspect that something else might be at play.
Which brings me back to my original problem of replacing the corrupted firmware in the satellites. I was finally able to login to my Orbi and followed the directions exactly to manually update the firmware in the satellites but ran into a Catch 22. The router recognized the satellites, however they were shown as "disconnected". And because they were disconnected they could not "selected" on the menu to upgrade the firmware. And of course they could not be "connected" because the firmware is corrupted!
Not sure what to do from here. I'll try again tomorrow to put the Xfinity modem in bridge mode but I'm not optimistic.
- CrimpOnMay 23, 2022Guru - Experienced User
My own practice is to connect a web browser directly to the satellite's own web page using the current IP address of the satellite.
(the login is "admin" and the same password as the router).
If the satellite appears to be dead (no on the network at all), then the only possible way to bring it back to life is to push firmware directly to it using TFTP:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
https://github.com/jclehner/nmrpflash
This is a highly technical adventure. I have done it successfully, and it took several tries.
