startrez
Jul 18, 2018Aspirant
RBR 50 WAN Port Stuck at 100M Speed
I can't seem to get the WAN port on my RBR50 Router up to 1000M speed, all of the non WAN ports are at the speed. Yes the device i am connecting to it supports 1000M ethernet link.
Any suggesti...
MillerM
Mar 17, 2019Tutor
Mine was the cable also but the Orbi included 5e cable was connected. Must have gone bad? I replaced with another cat5e and finally a cat6. Problem solved - back to my 477Mbps download speed
Mar 18, 2019Guru - Experienced User
Sometimes in box cables are not the best. Something new from a reputable cable company is recommended.
Thanks for letting us know.
