venksiva63
Aug 03, 2020Aspirant
RBR 50
ORBI Router AC 3000 I tried to reset my router after sitting idle for a month and now i dont see any lights Flashing when i tried to reset. I am unable to connect via ethernet cable as well....
venksiva63
Aug 04, 2020Aspirant
Power LED stay Green and if i try to hold the rest button. it still stay green and No Ring light at all.
Aug 04, 2020Guru - Experienced User
Can try this:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a WIndows 7 PC and the TFTP worked.
