Mikdo
Apr 01, 2022Aspirant
RBR 53 backhaul status is constantly changing
Hi there, I have installed the orbi rbr50 with two satellites with wired backhaul daisy chain. The backhaul status is constantly changing form “good” to “config sync”. does anyone have an ide...
- Apr 03, 2022Did a hard reset, everything is working fine now, thnx
Apr 01, 2022Guru - Experienced User
What Firmware version is currently loaded? Make sure both RBS and RBR FW versions are the same.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
