Mikdo
Apr 01, 2022Aspirant
RBR 53 backhaul status is constantly changing
Hi there, I have installed the orbi rbr50 with two satellites with wired backhaul daisy chain. The backhaul status is constantly changing form “good” to “config sync”. does anyone have an ide...
- Apr 03, 2022Did a hard reset, everything is working fine now, thnx
CrimpOn
Apr 01, 2022Guru - Experienced User
How often is 'constantly'?
- All the time. It never stays 'Good' for any length of time.
- A lot of times, but not every single minute.
If the Ethernet cables are disconnected, do the satellites sync over WiFi? (It is clear that wired backhaul promises faster speeds. The question is aimed at determining whether the satellites are working at all.)
Does the Orbi Attached Devices web page indicate the backhaul connection is 'Wired'?
Mikdo
Its changing every minute one time.
connection type indicate wired for both satellites at the web page.
When i disconnect the cabels the connection sync over wifi.
- CrimpOnApr 01, 2022Guru - Experienced User
There is a possibility that one (or both) of the Ethernet links is flawed. Backhaul links do not have to "all be the same".
Can you reconnect only the farthest away satellite Ethernet link and see what happens?
(it will take perhaps 5 minutes or more for the system to recognize that the wired link is available)
Then, connect only the first Ethernet link and observe.
When faced with a dilemma such as this, I usually bring both of the satellites into the room with the router, get them to sync over WiFi, and then use Ethernet patch cables to verify that they will sync over Ethernet.
(Silly question: is the performance using a WiFi backhaul terrible?)
- MikdoApr 03, 2022AspirantDid a hard reset, everything is working fine now, thnx
- FURRYe38Apr 03, 2022Guru - Experienced User
Enjoy. 📡
