Mikdo's avatar
Mikdo
RBR 53 backhaul status is constantly changing
Hi there, I have installed the orbi rbr50 with two satellites with wired backhaul daisy chain. The backhaul status is constantly changing form “good” to “config sync”. does anyone have an ide...
  • Mikdo's avatar
    Mikdo
    Apr 03, 2022
    Did a hard reset, everything is working fine now, thnx
