bmartz1
Oct 10, 2017Follower
RBR and RBS 50 handoff issues with streaming devices
Bit of a detailed issue... I'm running RBR50 w/ 2 RBS50s in a 3600 sq ft home. RBR is upstairs on one end of house, RBS 1 is upstairs on the other end of the house (at least 100ft away) and RBS ...
st_shaw
Oct 11, 2017Master
I agree with aaz that the router to satellite distance is probably too long.
It would be best to put the router in the middle of the house and the sats on either end. Run Cat5e from the ISP entry point to a central point for the router.
If it's impossible to move the router to the center of your house, you might get better results with daisy-chain enabled. Put the router on end end, first sat in the middle, and the second sat on the far end. The signal for the far sat should go through the middle sat with daisy-chain enabled.
