Orbi2020pc
Nov 27, 2023Tutor
RBR and RBS reboot
To eliminate potential bugs, I took it upon myself to do a factory reset, 90 minutes later the system is stable again, although the firmware has shown further bugs. 1. The factory reset on the RBR ha...
- Nov 27, 2023
I am a bit confused by the change in user name (Cvv to Orbi2020pc) and router (RBK853 to RBR50v2).
And does the topic remain the system rebooting under load, or.......?
I have the original RBR50 (version 1) and iPerf3 out the WAN port is limited by my 11Mb Spectrum upload:
Connecting to host speedtest.tds.net, port 5201
[ 5] local 192.168.1.2 port 49912 connected to 64.50.228.242 port 5201
[ ID] Interval Transfer Bitrate
[ 5] 0.00-1.01 sec 1.25 MBytes 10.4 Mbits/sec
[ 5] 1.01-2.00 sec 1.38 MBytes 11.7 Mbits/sec
[ 5] 2.00-3.01 sec 1.25 MBytes 10.4 Mbits/sec
[ 5] 3.01-4.01 sec 1.50 MBytes 12.5 Mbits/sec
[ 5] 4.01-5.00 sec 1.38 MBytes 11.7 Mbits/sec
[ 5] 5.00-6.01 sec 1.38 MBytes 11.5 Mbits/sec
[ 5] 6.01-7.01 sec 1.25 MBytes 10.4 Mbits/sec
[ 5] 7.01-8.00 sec 1.38 MBytes 11.7 Mbits/sec
[ 5] 8.00-9.01 sec 1.38 MBytes 11.5 Mbits/sec
[ 5] 9.01-10.01 sec 1.50 MBytes 12.7 Mbits/sec
[ 5] 0.00-10.01 sec 13.6 MBytes 11.4 Mbits/sec sender
When doing iPerf3 between two desktop computers connected directly to the RBR50, I get this:Connecting to host 192.168.1.3, port 5201
[ 5] local 192.168.1.2 port 49572 connected to 192.168.1.3 port 5201
[ 5] 0.00-1.00 sec 107 MBytes 896 Mbits/sec
[ 5] 1.00-2.00 sec 108 MBytes 909 Mbits/sec
[ 5] 2.00-3.00 sec 104 MBytes 873 Mbits/sec
[ 5] 3.00-4.00 sec 107 MBytes 899 Mbits/sec
[ 5] 4.00-5.00 sec 102 MBytes 859 Mbits/sec
[ 5] 5.00-6.00 sec 110 MBytes 923 Mbits/sec
[ 5] 6.00-7.00 sec 106 MBytes 887 Mbits/sec
[ 5] 7.00-8.00 sec 108 MBytes 910 Mbits/sec
[ 5] 8.00-9.00 sec 108 MBytes 906 Mbits/sec
[ 5] 9.00-10.00 sec 104 MBytes 875 Mbits/sec
[ 5] 0.00-10.00 sec 1.04 GBytes 894 Mbits/sec sender
[ 5] 0.00-10.00 sec 1.04 GBytes 894 Mbits/sec receiverNone of the Orbi systems support assigning different SSIDs to the 2.4G and 5G WiFi channels. If these other SSIDs are appearing, they may be from a WiFi extender?
CrimpOn
Nov 27, 2023Guru - Experienced User
Orbi2020pc
Nov 27, 2023Tutor
does this apply to RBR50 vers 2, with 1 Satellite(circa 2020)?.....I have users dropping all day as their wifi connections are moving and changing channels(my guess). They are losing work meeting connections .
I just rebooted the main router with paperclip. We had a 4 hr cable outage and my Router afterwards would NOT reconnect. I use my own 2 gig modem with comcast providing 400mb, and my Orbi is connected to modem via a cat 6 wire.
Can I set up sep SSID's via the Router, should I? Right now I see my Main network , then 2 others called 2gext and 5gext? Should I change the signal strength on 2g and 5g?
The random dropping is crazy. Could it be the Cable modem,(should it be in bridge mode)? I don't think it's my Modem, because Orbi is saying it's getting a 350mb. Whether that is a stable signal or not, who knows?
