Orbi2020pc
Nov 27, 2023Tutor
RBR and RBS reboot
To eliminate potential bugs, I took it upon myself to do a factory reset, 90 minutes later the system is stable again, although the firmware has shown further bugs. 1. The factory reset on the RBR ha...
- Nov 27, 2023
I am a bit confused by the change in user name (Cvv to Orbi2020pc) and router (RBK853 to RBR50v2).
And does the topic remain the system rebooting under load, or.......?
I have the original RBR50 (version 1) and iPerf3 out the WAN port is limited by my 11Mb Spectrum upload:
Connecting to host speedtest.tds.net, port 5201
[ 5] local 192.168.1.2 port 49912 connected to 64.50.228.242 port 5201
[ ID] Interval Transfer Bitrate
[ 5] 0.00-1.01 sec 1.25 MBytes 10.4 Mbits/sec
[ 5] 1.01-2.00 sec 1.38 MBytes 11.7 Mbits/sec
[ 5] 2.00-3.01 sec 1.25 MBytes 10.4 Mbits/sec
[ 5] 3.01-4.01 sec 1.50 MBytes 12.5 Mbits/sec
[ 5] 4.01-5.00 sec 1.38 MBytes 11.7 Mbits/sec
[ 5] 5.00-6.01 sec 1.38 MBytes 11.5 Mbits/sec
[ 5] 6.01-7.01 sec 1.25 MBytes 10.4 Mbits/sec
[ 5] 7.01-8.00 sec 1.38 MBytes 11.7 Mbits/sec
[ 5] 8.00-9.01 sec 1.38 MBytes 11.5 Mbits/sec
[ 5] 9.01-10.01 sec 1.50 MBytes 12.7 Mbits/sec
[ 5] 0.00-10.01 sec 13.6 MBytes 11.4 Mbits/sec sender
When doing iPerf3 between two desktop computers connected directly to the RBR50, I get this:Connecting to host 192.168.1.3, port 5201
[ 5] local 192.168.1.2 port 49572 connected to 192.168.1.3 port 5201
[ 5] 0.00-1.00 sec 107 MBytes 896 Mbits/sec
[ 5] 1.00-2.00 sec 108 MBytes 909 Mbits/sec
[ 5] 2.00-3.00 sec 104 MBytes 873 Mbits/sec
[ 5] 3.00-4.00 sec 107 MBytes 899 Mbits/sec
[ 5] 4.00-5.00 sec 102 MBytes 859 Mbits/sec
[ 5] 5.00-6.00 sec 110 MBytes 923 Mbits/sec
[ 5] 6.00-7.00 sec 106 MBytes 887 Mbits/sec
[ 5] 7.00-8.00 sec 108 MBytes 910 Mbits/sec
[ 5] 8.00-9.00 sec 108 MBytes 906 Mbits/sec
[ 5] 9.00-10.00 sec 104 MBytes 875 Mbits/sec
[ 5] 0.00-10.00 sec 1.04 GBytes 894 Mbits/sec sender
[ 5] 0.00-10.00 sec 1.04 GBytes 894 Mbits/sec receiverNone of the Orbi systems support assigning different SSIDs to the 2.4G and 5G WiFi channels. If these other SSIDs are appearing, they may be from a WiFi extender?
CrimpOn
Nov 27, 2023Guru - Experienced User
CrimpOn
Now I am even more confused. This post has only one Original Poster (OP) and no mention of RBR850 or iPerf3. Somehow my web browser has mangled different community forum threads together. (sigh)
If there has been a cable outage, it is probably a good idea to turn everything off (ISP modem, Orbi, satellites). Then restart the modem. wait for it to settle down. power up the router. wait until it turns blue. power up the satellites.
- Orbi2020pcNov 27, 2023Tutor
Maybe I accidentally hijacked the Rbr853 thread ...sorry. Mine is unstable Wifi RBR w/1RBS satellite
- FURRYe38Nov 27, 2023Guru - Experienced User
So lets start this again with the following:
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the size of your home? Sq Ft?What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
