ipp
Mar 15, 2021Follower
RBR dropping wifi connection
I have been using RBR50 for the past 3 years. Had no issues until last week. Wifi connection keps dropig off. Hae to reset the ruouterand it woks for a whil and requires resetting. I have reset the r...
Mar 15, 2021Guru - Experienced User
Any RBS deployed? What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try setting Auto on 2.4Ghz. 40 on 5Ghz.
Armor, Circle, Daisy Chain, Fast Roaming, Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
ipp wrote:I have been using RBR50 for the past 3 years. Had no issues until last week. Wifi connection keps dropig off. Hae to reset the ruouterand it woks for a whil and requires resetting. I have reset the router at least 10 times in last 2 days. Router Firmware Version V2.7.2.104. 2.4MHX is set Ch #6 and 5GHZ is set to 48. Please help.
