ipp
Mar 15, 2021Follower
RBR dropping wifi connection
I have been using RBR50 for the past 3 years. Had no issues until last week. Wifi connection keps dropig off. Hae to reset the ruouterand it woks for a whil and requires resetting. I have reset the r...
rubberbay
Mar 16, 2021Tutor
Growling list of the same complaint here:
https://www.reddit.com/r/orbi/comments/m5l3vk/orbi_dropping_dns/
- vajimMar 16, 2021Master
rubberbay wrote:Growling list of the same complaint here:
Thanks
Perhaps lets share this with my friends:
- Ha_Ku_NaMar 16, 2021Luminary
I'm on 2.7.2.104 and using a pi-hole as DNS server (configured in Orbi "Use These DNS Servers" -> only pi-hole IP configured in "Primary DNS"). Never saw this issue.
If someone has issues with his Orbi system I suggest this procedure:
1) take a backup of the config on Orbi
2) Reset to factory default
3) setup Orbi and reload the saved config from step 1
If this does not help, then we can think about a firmware downgrade or reapply of the same firmware file again.
Ha_Ku_Na wrote:I'm on 2.7.2.104 and using a pi-hole as DNS server (configured in Orbi "Use These DNS Servers" -> only pi-hole IP configured in "Primary DNS"). Never saw this issue.
Your suggestions are already proven to be of no help. Read the 100's of posts in here. Then on top of that you tell people to reapply the same firmware. Now that's superior advice.
The moderators here will be telling you to remove you disclaimer flame.
