Sethforman
Jan 16, 2021Aspirant
RBR stopped working and won’t factory reset
Loved my Orbi RBR50 mesh system for just over two years. Best system I’ve ever had. One day I did a reboot as I do from time to time, and the router never came back on or at least working. Tried every...
- Jan 17, 2021
Any 20, 40 or 50 series RBR will work with RBS50s.
Jan 16, 2021Guru - Experienced User
So if you disconnect the RBR from the ISP modem and just connect 1 wired PC to the RBR, press the reset button for 15 seconds then release. The top ring LED should flash WHITE then begin to pulsate WHITE, can you access the RBRs web page at 192.168.1.1 with the wired PC and a web browser?
- SethformanJan 16, 2021AspirantThank you for the speedy reply! Router is an Arris TM1602 and ISP is optimum. I’ve tried the direct connect before but going to again now and in the past could not get to the RBR page. Be back soon with updated result when I try again. Thank you!
- SethformanJan 16, 2021AspirantSorry, stupid question. Do I need to be online to reach the RBR webpage or just offline and connected directly with an Ethernet to the router?
- FURRYe38Jan 16, 2021Guru - Experienced User
Connected directly with an Ethernet to the router with your wired PC. Disconnect the RBR from the ISP Modem.
- SethformanJan 16, 2021AspirantLaptop connected to the modem, router not connected to anything and in pulsing white mode after reset. I go to the gateway 192.168.1.1 and it says I’m not connected to my Orbi WiFi. Did I do anything wrong?
