cdbarker
Sep 25, 2024Guide
RBR050 - Web cannot login fully to router and app doesn't show all satellites
Hi I recently noticed that I cannot now login to my RBR050 via web. I can login but when trying to display the homepage, I just get 2Please wait a moment" with a whirring animation while it tries to...
- Oct 01, 2024
Just to update you guys. I resolved the issue by restoring the October 2021 config backup that I had taken, so I'm assuming that the configuration must've got corrupted somehow.
I did start to notice weird things happening on the Network Map on my Orbi app when I noticed that the satellite, that eventually disappeared, was daisy chained to another satellite even though my wireless config wasn't set up for daisy chaining. I did have a lot of devices (40 out of 50+) with reserved LAN addresses also which may have had an impact or maybe the 50+ devices is starting to make the router "creak". I haven't configured as many reserved LAN addresses this time.
Anyway, I avoided the factory reset or firmware updates, so I'm happy. Thanks again for your responses.
cdbarker
Sep 25, 2024Guide
I've just tried tapping on the Advanced tab and can see that I do get some pages to render but when I tap on Attached Devices I receive the below error?
400 Bad Request
This server does not support the operation requested by your client.
Sep 25, 2024Guru - Experienced User
Have you tried a different browser or device?
- cdbarkerSep 25, 2024Guide
Hi plemans thanks for the reply. Yes, I have tried different web browsers and different Orbi app (android/iOS) but they all behave the same way.
So to summarise, all of my 3 satellites appear to be operational.
1. One satellite is not visible in the Orbi app and any mobile device.
2. Accessing the router via the web in any browser receives a 400 Bad Request response when trying open Advanced>Access Control
Basic>Attached Devices
Basic>Home
Is the web config file corrupted possibly? i.e somethiing to do with the ACL that relates to the 1 satellite that is not displaying in the app.
Looking through the forum, it appears that other people have had this issue and have had to revert back to a factory rest. Crazy! I've been on this firmware for ages and it has only recently gone wrong. I have a .cfg file from August 2021 which I may try to restore and see what happens but I'm not so sure as the router/satellites are working. I don't want to perform a factory reset.
