OvidiuVonm
Jul 07, 2021Aspirant
RBR10 - extra satellite- compatibility
Hello,
I have a RBR10 - Orbi Dual-band AC1200 Mesh WiFi Router(RBR10) and i would like to get some extra satellites. Currently i have a RBS10 satellite and at least in Sweden i cannot find this model of satellites (stand alone) . Anyone knows if i can get another satellite model that would be compatiblie with the router that i have ?
Thanks in advance!
You might ask NG support or check out NGs store if there is anything available.
You might try a EX7500 extender to see if that might work as a alternative...
- OvidiuVonmAspirantI have a EX7320 but it seems that one does not work.
Is the FW up to date on this EX unit?
Possible that extenders may not work either.
