theram
Aug 01, 2021Follower
RBR10 flashing red - cannot reset to default settings
Ive had this router for a year an has worked perfectly. we were gone over the weekend and when we came back, the router was flashing red. i have verified our modem is working fine, attempted to reset...
Nov 03, 2021Guru - Experienced User
Any progress on this?
theram wrote:
Ive had this router for a year an has worked perfectly. we were gone over the weekend and when we came back, the router was flashing red. i have verified our modem is working fine, attempted to reset the orbi router multiple times including attempts to reset the router to factory settings. however, when i attempt to do put a pin in the back of the unit to reset, the light just flashes red, and continues to flash red and never resets. i do not have an ehternet port on my laptop so i havent been able to connect directly to the router.
any help would be so appreciated!!
