JoKo_BN
Jan 05, 2022Aspirant
RBR10 Mesh WLAN Geräte kommnizieren nicht untereinander
Hallo Allerseits, ich habe ein Meshsystem mit RBR10 und zwei Satelliten installiert. Das System lässt keine Kommunikation der WLAN Geräte untereinander zu. Es geht z.B. kein Streaming vom Handy in d...
Jan 05, 2022Guru - Experienced User
what modem/gateway is the rbr10 connected to?
- JoKo_BNJan 05, 2022AspirantHi
It’s connected to the Internet via a FRITZ!Box 7560 (Ethernet cable from FRITZ!box to Orbi)
Regards
Joerg- plemansJan 05, 2022Guru - Experienced User
The fritz box has its own integrated router and can cause a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
