ahashemi
Apr 22, 2022Aspirant
RBR10 Mesh
Hi, I have an Orbi Netgear Mesh system. I was able to check the status of the satellites and speed check via app. Recently, when I open the App, it is indicating router is not connected. The Route...
KevinLiT
Apr 22, 2022NETGEAR Moderator
Hi ahashemi,
I understand that you are trying to access your RBR10 but the app is not recognizing the device. Please navigate to the app store on your device to ensure that you are using the most recent version of the app. If you can not remember your password or your security questions you may need to factory reset the device.
Please navigate to the link below for instructions on how to factory reset your device:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Let me know if this helps!!
Best,
Kevin
Community Team
- ahashemiApr 25, 2022Aspirant
Thanks Kevin
