corbenator
Mar 17, 2021Tutor
RBR10 Orbi AC1200 Dual Band Mesh Wifi Router CONSTANTLY disconnects
We purchased the Orbi Dual-Band Mesh Wifi Rouer with 2 satellites back in November. It has been a dream so far, but in the last week we've had multiple issues with our wireless network going down. He...
Carpka01
Mar 19, 2021Aspirant
A guy on another thread for this same problem said "downloaded previous version and manually installed it, fixed the issue with stability of internet connection."
Version with problem : V2.6.2.104
Version without probelm : V2.6.1.36
I personally have not tried this. But I will be when I get home from work!
- ReithMar 22, 2021ApprenticeGo into NTP settings. Change the DST from Netgear to Manual server. Type time.nist.gov and will resolve your wifi issue. It is because of the time change recently. See attached PDF where to make the changes
- corbenatorMar 22, 2021Tutor
I'm going to give this a shot. Unfortunately, the firmware version listed without any connectivity issues doesn't appear on the product page. The most recent update is version 2.5.1.30. I'm still going to give it a shot and see what happens.
- antinodeMar 22, 2021Guru
> A guy on another thread for this same problem [...]
Thanks for the helpful link.
> Version without probelm : V2.6.1.36> the firmware version listed without any connectivity issues doesn't
> appear on the product page.Which model did this "A guy" have? Which model do you have?
