corbenator
Mar 17, 2021Tutor
RBR10 Orbi AC1200 Dual Band Mesh Wifi Router CONSTANTLY disconnects
We purchased the Orbi Dual-Band Mesh Wifi Rouer with 2 satellites back in November. It has been a dream so far, but in the last week we've had multiple issues with our wireless network going down. He...
Carpka01
Mar 19, 2021Aspirant
A guy on another thread for this same problem said "downloaded previous version and manually installed it, fixed the issue with stability of internet connection."
Version with problem : V2.6.2.104
Version without probelm : V2.6.1.36
I personally have not tried this. But I will be when I get home from work!
corbenator
Mar 22, 2021Tutor
I'm going to give this a shot. Unfortunately, the firmware version listed without any connectivity issues doesn't appear on the product page. The most recent update is version 2.5.1.30. I'm still going to give it a shot and see what happens.
- antinodeMar 22, 2021Guru
> A guy on another thread for this same problem [...]
Thanks for the helpful link.
> Version without probelm : V2.6.1.36> the firmware version listed without any connectivity issues doesn't
> appear on the product page.Which model did this "A guy" have? Which model do you have?
