phkhong's avatar
phkhong
RBR10 Region change
I purchased a RBR10 online last November and only just realised that the wireless region is set to North America and it is greyed out and unable to change in the webadmin - I am in Australia.
What is the best option to change the region setting? I suspect it is interferring with my other 5GHz AP
    • phkhong's avatar
      phkhong
      Thanks. Followed the instructions and changed region to AU and the region selection is enabled.
      5GHz channel is still "stuck" at 157. Was expecting this to be Auto like 2.4GHz channel
      • CrimpOn's avatar
        CrimpOn
        Guru
        There are two 5G channels.  The "front" (or user facing) 5G channel can be selected from 36-48.  48 essentially "combines" channels 36-48 creating the biggest possible bandwidth for devices that can take advantage of it.  The "backhaul" 5G channel for communication between Orbi devices is limited because of radio frequency restrictions.  In many countries, channel 157 is about the only "fully open" channel.  Where no higher frequencies are "fully open", the Orbi complies with restrictions to avoid weather & military radar in the area.
        There is a long discussion about this issue in this post:
        https://community.netgear.com/t5/Orbi/5Ghz-channels/td-p/1538610
