Breakaway9
Jan 19, 2021Guide
RBR10 Remote Access
I use the Android Orbi App Version V2.7.2.1371. I have a RBR50 at one location. I have a RBR10 at another location. I have "Anywhere Access" enabled on both. When I am at the RBR50 location, it says ...
CrimpOn
Jan 19, 2021Guru - Experienced User
Having two Orbi systems on one Orbi "app" certainly should work from both locations. If the question is posted in the community forum for the app, somebody may have a suggestion:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
(It is understandable that Netgear created separate forums because there is such a wide variety of Netgear products that a single forum would not be managable, but it's not at all "obvious" why some topics have separate forums and others are lumped together.)
