striker69's avatar
Oct 19, 2021
RBR10 router
System Is Working With Two Satellites, Problem Is The Light On The Front Of The Router Used To Be Blue. Now It's A Steady Amber. I Rebooted The Router And BeforeThat I Restarted The Modem. I Have ATT...
  • striker69's avatar
    striker69
    Oct 28, 2021
    Stupid Me, Plugged In The Cable To The Wrong Port, Needed To Switch From Ethernet To Internet. Fixed!
