striker69
Oct 19, 2021Star
RBR10 router
System Is Working With Two Satellites, Problem Is The Light On The Front Of The Router Used To Be Blue. Now It's A Steady Amber. I Rebooted The Router And BeforeThat I Restarted The Modem. I Have ATT...
- Oct 28, 2021
Stupid Me, Plugged In The Cable To The Wrong Port, Needed To Switch From Ethernet To Internet. Fixed!
Oct 19, 2021Guru - Experienced User
Is it working?
Other than the led's whats going on with it?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
striker69
Oct 30, 2021Star
Yes It's Working Fine. It Was Working, I Knew The Light Should Have Been Blue. Somewhere Along The Line I Did A Refresh And Must Have Plugged It In Wrong.
- FURRYe38Oct 30, 2021Guru - Experienced User
Enjoy.
