striker69
Oct 19, 2021Star
RBR10 router
System Is Working With Two Satellites, Problem Is The Light On The Front Of The Router Used To Be Blue. Now It's A Steady Amber. I Rebooted The Router And BeforeThat I Restarted The Modem. I Have ATT...
- Oct 28, 2021
Stupid Me, Plugged In The Cable To The Wrong Port, Needed To Switch From Ethernet To Internet. Fixed!
striker69
Oct 30, 2021Star
Yes It's Working Fine. It Was Working, I Knew The Light Should Have Been Blue. Somewhere Along The Line I Did A Refresh And Must Have Plugged It In Wrong.
Oct 30, 2021Guru - Experienced User
Enjoy.
