Nightowl66
Jun 19, 2023Aspirant
RBR10 satellites slow
I just had 200mb fiber optic installed in my house. I get 200+ if I'm connected to the main router, but if I am connected to one of the satellites the speeds are anywhere from 10mps to 60. What can I...
michaelkenward
Jun 20, 2023Guru - Experienced User
Did you reset your Orbi system and set it up from scratch for your new Internet service?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
- Nightowl66Jun 20, 2023Aspirant
I did not reset the router after getting fiber installed.
Firmware version V2.7.4.24.
The fiber comes into the ouse to a little box, not sure if it is a modem, then Ethernet comes out to the router. No LAN ports.
- KevinLiTJun 20, 2023NETGEAR Moderator
Hello Nightowl66,
Welcome to the NETGEAR Community!
I understand that you are having network discrepancies between your RBR10 and your RBS10. This could be due to the placement of the Orbi satellites. Please relocate your Orbi satellites in accordance with the location recommended settings. Changing your preamble mode from automatic to long may resolve connection issues for devices with weaker wireless signals. If your RBR10 is between your satellites be sure to toggle off the "Daisy-Chain topology feature.
To toggle off the Daisy-Chain topology feature please navigate to the following settings at Orbilogin.com:
ADVANCED > Advanced setup > Wireless settings > Backhaul topology > Uncheck Enable Daisy-Chain topology.
To change the preamble mode on your RBR10 please navigate to the following settings at Orbilogin.com:
ADVANCED > Advanced setup > Wireless settings >Preamble mode > Long Preamble.
Please use the recommended Orbi placement within the link below as a reference:
Where should I place my Orbi satellite? | Answer | NETGEAR Support
Best,
Kevin
Community Team
Thanks for the reply. I can change the preamble mode in the 2.4 GHZ setting, but the 5GHZ is greyed out, it is set to automatic.
