nashville_bill
Mar 27, 2023Aspirant
RBR10 System Is Working With Two Satellites has Orange LED
My Mesh system is working correctly, with good internet connection, but has Orange LED. I've rebooted the RBR10, but the LED flashes White for a long time and then changes to a solid Orange (the sate...
- Mar 28, 2023
Hello nashville_bill ,
Welcome to the NETGEAR Community!
Please do not be alarmed by the lights on the Orbi. No lights on the Orbi means that it is working as it should. The white lights indicate that your Orbi is powering up. If the amber light does not go away on its own a factory reset may be required.
Please refer to the following link for more information about your Orbi led lights:
What do the LEDs on my Orbi router and satellite mean? | Answer | NETGEAR Support
Best,
Kevin
Community Team
Mar 27, 2023Guru - Experienced User
What modem/gateway do you have it connected to?
If the internet is working, i'd be betting on you being in a double nat.
nashville_bill
Mar 28, 2023Aspirant
Thanks for your reply.
I'm using the T-Mobile 5G home internet, which appears to be working as it should..
I woke up this morning and the RBR10 had no LED, but was still working. I just rebooted the system now and it has a solid white LED again.
Bill
- michaelkenwardMar 28, 2023Guru - Experienced User
That tells us a bit about the modem technology, but nothing about the device itself. Only a model number helps.
How are the satellites arranged? Both aiming at the router? Or in a "daisy chain" with one and then the other?
How far apart are they?
