hoeks
Jun 13, 2023Follower
Rbr10 will not conect to the internet
Hi everyone. I recently purchased a second hand Orbi Rbr10 with 2 satellites. I can get the wifi to transmit from the Orbi to all of our devices, but there is no internet connection. I have a Huawei ...
Iramiller
Jun 20, 2023Aspirant
hoeks wrote:
Hi everyone.
I recently purchased a second hand Orbi Rbr10 with 2 satellites. I can get the wifi to transmit from the Orbi to all of our devices, but there is no internet connection. I have a Huawei ONT (can't find the model #) through Spark in NZ. They have supplied the settings to use (in the attached screenshot) and I've set the ones I can find (really only the PPP username and password) when I login to the router, but most of them I can't see if they're right. When I login to the router it doesn't show an IP address so I've tried the steps on the troubleshooting guide but cannot get any internet connection at all. Can anyone help?
I think it's configuration issue of your Orbi Rbr10 router. I don't have proper instructions for you but I recommend to contact manufacturer's support. They will guide you through necessary steps to establish an internet connection.
Iramiller
Iramiller wrote:
hoeks wrote:
Hi everyone.
I recently purchased a second hand Orbi Rbr10 with 2 satellites. I can get the wifi to transmit from the Orbi to all of our devices, but there is no internet connection. I have a Huawei ONT (can't find the model #) through Spark in NZ. They have supplied the settings to use (in the attached screenshot) and I've set the ones I can find (really only the PPP username and password) when I login to the router, but most of them I can't see if they're right. When I login to the router it doesn't show an IP address so I've tried the steps on the troubleshooting guide but cannot get any internet connection at all. Can anyone help?I think it's configuration issue of your Orbi Rbr10 router. I don't have proper instructions for you but I recommend to contact manufacturer's support. They will guide you through necessary steps to establish an internet connection.
Did you fixed the issue or not? Still are you looking for solution? PrepaidGiftBalance
