Tazzin38
Feb 26, 2023Aspirant
RBR10 won't connect
Greetings, I was given an RBR10 router with 2 satellites. The light on the router never turned solid white, but blue. After several minutes I continued with the install. When it came time to connect...
CrimpOn
Feb 27, 2023Guru - Experienced User
Tazzin38 wrote:
Greetings,
I was given an RBR10 router with 2 satellites. The light on the router never turned solid white, but blue. After several minutes I continued with the install. When it came time to connect my phone to the Orbi network,
Assuming that the Orbi 'app' was being used to set up this system, correct?
"when it came time" is a little ambiguous. (I have never used the &%(#^^ 'app' to set up a router, and am thus unfamiliar with the steps.) For example:
- The app found the router...?
- The app said to connect the router to the Internet Service Provider with an Ethernet cable...?
- At some point the app invited you to change the WiFi name and password....?
The "devil is in the details."
