ZBarnett22
Apr 15, 2021Aspirant
RBR10/RBK13 and 2 Satellites no performing as expected.
Hi, I have this mesh system with firmware V2.6.2.104. My router is in the basement, with a satellite stacked on top on the 1st floor (about 12 ft apart plus building materials), with another sate...
ZBarnett22
Thanks for the response! The material between the basement and 1st floor is just wood. There is probably some duct work between 1st and 2nd. Since my original post, I've tried moving the 1st floor satellite to a guest bedroom over the garage, so now it is configured like an upside down L, with the bottom of the upside down L being the router, the middle point being the 2nd floor loft, and the end point being the guest bedroom (also 2nd floor). The guest bedroom is is trying to connect via hub-spoke to the router, but it should definitely be connecting via daisy-chain, which I do have enabled. Do you know if there is a way to force it?
Edit: Since this reply, they have daisy-chained themselves. This is probably the best configuration for my home. I didn't actually measure the distance between points before and I was grossly over-estimating. Writing this post forced me to break out the measuring tape, so I bet this will work well now.
Apr 15, 2021Guru - Experienced User
Hope it works well for you!
I usually caution people with daisy chaining on the single/dual band systems as it drops speeds and increases latency more than in the triband systems
- ZBarnett22Apr 15, 2021Aspirant
Ok thanks, with that information I may consider going with just the one satellite.
- plemansApr 15, 2021Guru - Experienced User
I'd try multiple setups.
I probably moved my satellites around once a week for a month or 2 just to find the optimal placement for coverage and daisychain/direct connection.
