SANJEEVXN
Mar 14, 2020Aspirant
RBR20 - dont know answeres to security questions
I have forgotten systems admin password to complete set -up of my Orbi. I've tried "password" and all the passwords I usually use but keep getting login failed. To recover password I have followed ins...
SANJEEVXN
Appreciate your help.
I tried re-setting my router and satelite bot flashed white and then stopped flashing with no light at all.
I also called our Internet Service Provider as I went through and was advised that VLAN requires set up...
CrimpOn
Mar 14, 2020Guru - Experienced User
SANJEEVXN wrote:I tried re-setting my router and satelite bot flashed white and then stopped flashing with no light at all.
When the Orbi has "no light at all" on the top, it should be ready for setup. Do you have a desktop or laptop that can be connected to one of the Orbi LAN ports?
VLAN is required to provide television in some situations. The ISP should point you to one of their web pages with instructions on what they need. This can only happen after you gain access to the Orbi and set it up.
