GN100
May 18, 2020Follower
RBR20 - failing to update firmware
My ORBI RBR20 with 2 satellites fails to update the firmware ..... and the support from Netgear is non existent. Checking the app (v2.5.1.2), it shows the firmware as 2.3.5.26AU ...... I have had...
Tenoates
May 19, 2020Tutor
You have to manually update the firmware.
Download the 2 firmware (sat & router). They both have the same file name so make sure you track which is which, by saving them in different folders.
Then login to orbilogin and manually update the firmare in the dvanced/admin section.
Do the sat first. then the router after
