reshuisr2
Apr 04, 2023Follower
rbr20 - rbs20 vs sxk30 -sxs30 (ethernet wired 1gbps)
I currently own a Triband rbr20 - rbs20 want to upg to Dual Band sxk30 -sxs30 with wired 1gbps backhaul. Would it make sense? today rbr20 - rbs20 are 20feet appart with no wired bakhaul (but is a triband system). Today 5 new devices that support wifi 6. have 3 4k tvs sometimes streaming simultaniously (rbr20 - rbs20 / doing well here). would sxk30 -sxs30 with ethernet backhaul perform better/worse/the same?
1 Reply
It'd perform a little better but I couldn't 100% say if it'd be worth it. The RBK20 system is pretty solid. You could try them with a wired backhaul and see how they work because it'd be similar to the SXK30 system.
Again, not 100% the same as the 30 series has some generational improvements
