ben205
Jul 21, 2020Follower
RBR20 - satellite options
Hi All Need to get a new wireless Satellite for my RBR20 as one RBS20 is now dead and needs to be replaced. Any recommendations as to best options or any restrictions at all I need to be aware ...
- Jul 21, 2020
you can use:
RBS20RBW30
RBS40
RBS40V
RBS50
RBS50Y
The only thing to keep in mind is the 50 series have the 1733mbps backhaul. Your device wouldn't be able to use the full speed (only the 866mbps) but it wouldn't hurt anything if you found one cheaper than the others.
What issue are you having with your RBS20? maybe its a fixable issue.
Jul 21, 2020Guru - Experienced User
you can use:
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
