Mock19
Jun 23, 2022Aspirant
RBR20 - Xbox only 100-200mbps Wired?
Hello, I was wondering if anyone may be able to help. I am a bit stumped. I have the Orbi RBR20 and an Xbox Series X as well as a PS5. I have Xfinity's 600mbps package, and my own modem an Arriss S...
Mock19
Jun 24, 2022Aspirant
Hi,
The PC is getting between 585-686mbps wired to the satellite's ethernet. Wifi is currently 384mbps but i dont have the antenna screwed on the wifi card atm...looking for it to test it. (PC is in the room i needed the Orbi for)
Im just at a loss. Im dont know a ton about routers but i know enough and have troubleshot this enough that its pointing to the Orbi being the issue. My old R7000 Nighthawk got 300mbps on a 200mbps plan (xfinity over delivers here usually) over wifi on the consoles.
Id be fine if this was a server thing, but by bypassing the orbi and going straight to the modem wired and seeing the correct speeds raises the red flag.
Jun 24, 2022Guru - Experienced User
If those are the only devices with slow down, it tends to be which server they're selecting or time of day.
When the computer and the wireless devices are getting full speed, it tends to not be the router.
Have you tried a different server on the gaming consoles?
- Mock19Jun 24, 2022AspirantI did the speedtests on each console within 15 minutes both over wifi and ethernet w the Orbi, then unplugged and put them straight into the modem. I cant imagine there being a nearly 400mbps drop in that time frame. As soon as I wired to the modem i was at my 600mbps.
