nettyvam
Nov 22, 2024Aspirant
RBR20 & RBS20: Additional bands detected
Hi all, I'm running at RBR20 & RBS20 mesh setup. While using Netspot to determine the signal strength between the router(RBR20) and satellite unit(RBS20), i found that besides the 2.4G & 5G bands for...
CrimpOn
Nov 22, 2024Guru - Experienced User
What you are seeing is normal.
There is a difference between frequency bands (channels) and WiFi SSIDs.
Most Orbi routers broadcast Beacon Frames*** on three channels (there are some "dual channel models"):
- 2.4G channel for user devices and potential router to satellite connection****.
- 5G channel for user devices
- 5G channel for router to satellite connections
On these channels, the router broadcasts Beacon Frames for a variable number of SSIDs.
- Primary WiFi SSID will be broadcast on the 2.4G and user 5G frequencies.
- If the Guest WiFi option is enabled, the Guest SSID will be broadcast on the 2.4G and user 5G channels.
- If the router has enabled an IoT network (which the RBR20 does not support), that SSID will be broadcast on the channels that have been enabled (IoT allows using 2.4G only, 5G only, both, or neither)
- The "hidden" SSID broadcasts Beacon Frames on 2.4G frequency and the 5G router to satellite frequency. Scanning programs such as NetSpot and WiFi Info View (free for Windows from Nirsoft) detect and report on WiFi networks with both visible and "hidden" SSIDs.
*** Beacon Frames are a part of the management mechanism for WiFi:
https://en.wikipedia.org/wiki/Beacon_frame
**** If the router and satellite cannot make a strong connection on the 5G frequency, they attempt to connect on the 2.4G frequency. This hidden network is always "there" in case it is needed.
nettyvam
Thank you so much for the detail sharing. Didn't know about the beacon frame until now!!
Apart from the 2.4G and 5G 'hidden' channels, there are 2 other visible 5G channels (They are different channels on the 5G band, correct?). I have noticed my devices connecting (it shows on Netspot which mac address is the phone, ie the client-device connected to) to either one of them and it seems to be random.
If one of the 5G channels is for broadcasting beacon frame, will a client-device still be able to connect to it? (I would think we can put aside the 2.4G band for now, assuming it works exactly the same way, apart from it being on the 2.4G band.)
Or will the router perhaps randomly assign one if it's mac address for 5G beacon frame broadcasting and it's other mac address for 5G client-device connection, meaning the 2 mac addresses may be assign the opposite role the next time the router is power up again. Note that both appear with the same SSID.They are not 'hidden'.
Ive been trying to nail which is doing what so that i can take a proper dBm reading for both router-satellite and node-client-device to best position the satellite and this has been kinda frustrating.
